Page 1 of 2
Slight Dragster engine Problem
Posted: Sat Jun 11, 2016 3:55 pm
by TED CRUD
On my way back from Kelso i hit a long stretch and had Dragster flat out blasting past a few scooters ,towards the end it pulled back for a second so i dropped the revs and throttled on .It did not pull on as normal,so i decided to pull over .It would not go on the stand easily ,The reason being the wheel was wobbling about abit
[URL=http://s245.photobucket.com/user/0 ... .jpg[/img][/url]
[/u[URL=http://s245.photobucket.com/use ... .jpg[/img]rl]
Re: Slight Dragster engine Problem
Posted: Sun Jun 12, 2016 8:25 pm
by DigDug
Blimey!
Posted: Sun Jun 12, 2016 9:14 pm
by holty
oh dear, that looks a bit off a mess, i think you can buy a support for the rear wheel to prevent this happening, i belive polini make them, i bet you were pleased you pulled over to have a look, could have been a serious accident with a breakage like that, are you going to get it welded back up, or buy another casing ?
best regards,
holty
Posted: Mon Jun 13, 2016 12:06 pm
by shocky
Ouch what sort of power have you got ?
Posted: Mon Jun 13, 2016 8:56 pm
by T5-190
FECK !!!!!!!!!
Posted: Tue Jun 14, 2016 12:40 am
by shamrockexpress
shocky wrote:Ouch what sort of power have you got ?
Not very much now
Posted: Tue Jun 14, 2016 6:56 am
by shocky
Lol
Sent from my SM-G903F using Tapatalk
Posted: Tue Jun 14, 2016 6:09 pm
by lozmondo
Early casing without the rolling nut?...lucky escape
Posted: Tue Jun 14, 2016 10:09 pm
by TED CRUD
I am /was running standard 180 ,54mm crank 2mm packer ,Scorpion exhaust was a early engine .I have a rolling nut engine case of a Diamond Geezer Rick !!!
It was a lucky escape ,Basically the belt and mudguard held the casings together till i pulled over .
Going to fit a Engine brace and a few upgrades
Posted: Sun Aug 07, 2016 6:51 pm
by TED CRUD
And so it starts
