Page 11 of 20
Re: lambretta 290 rotax
Posted: Thu Sep 07, 2017 8:16 pm
by holty
garry inglis wrote: ↑Wed Sep 06, 2017 7:05 pm
thats some neat welding on the basket why not try for an 8 plate packer plate for casing extend kickstart shaft go on holty be the first go on go on
ive got 2 5mm packers and the extended center bush and kickstart extension , i intend to get 2 sixplate conversions and see how many plates i can get in
Posted: Thu Sep 07, 2017 8:53 pm
by garry inglis
Can't wait to see how that turns out I hope you have a slip joint in the exhaust to allow for packers
Posted: Fri Sep 15, 2017 4:34 pm
by holty
i made the exhaust spring mounted at the stub, but didnt put a slip joint as its not going to need the barrel moving up or down as ive already machined my packer plate to the required thickness to get the port timings where they need to be. i made a small bettery tray the other day, plus a bracket for the fuel tank, got my external pick up, thats my next job.
Posted: Fri Sep 15, 2017 4:37 pm
by holty
Posted: Thu Sep 21, 2017 9:44 pm
by holty
external pick up fitted and flywheel timing marks added and trigger
Untitled by
stephen holt, on Flickr
clutch finished off just waiting for plates to arrive
Untitled by
repaired rear brake pivot hole, reamed out hole and added 2 oilite bushes
Untitled by
kickstart shaft and extending piece
Untitled by
kickstart extended i had to extend the slot and made a packer to go behind the spring
Untitled by
Posted: Fri Sep 22, 2017 5:08 am
by garry inglis
Great work holty that clutch looks deep
Posted: Fri Sep 22, 2017 10:15 pm
by holty
thanks garry, ive polished the side case and fitted an sx kickstart
Untitled by
Posted: Fri Oct 06, 2017 9:21 pm
by holty
had a re think on the tank and moved it forward to make more room tor the carb, i will put my battery and tray somewhere else
Untitled by
i have also added another bracket to the exhaust, fastens to 2 headbolts and has a rubber insert
Untitled by
and today fitted new front sprocket, chain and 7 bgm race clutch plates and mb springs
Untitled by
Posted: Sat Oct 21, 2017 6:40 pm
by holty
so engine is all finished and ready to fit, so i have taken the engine out of my rb250 gp as that is what it is going in, done a small repair behind the number plate and fitted the tank upto now, been to rayspeed today and got the rest of the parts i need.
Untitled by
Untitled by
Untitled by
Posted: Sat Oct 21, 2017 6:48 pm
by garry inglis
The packers under the casing worked well did the kickstart work ok looks great
