Been putting in some seat time recently, trying to shoot some decent video to post. So far, got some OK video but the audio is pure crap. First gear sounds good but by second, the wind noise drowns everything out and is too much for even me to handle. I'll keep working on it though in the hopes of putting something fun together for ya'll.
In the meantime, I figured I might as well try to dial everything in as best I can until I can schedule some dyno time. Out here in Southern California, moto dynos with Lambretta experience flat don't exist. Throw in all the extraneous crap on my bike and you get the point. Hopefully, I can connect with someone sick enough to take it on for the freak factor if nothing else. But I digress...
Sooo, I decided to setup my FAST Air/Fuel Meter to see if the jetting was where it should be. It feels pretty close but there are a few spots where things seem like they could be improved. This uses a single wideband O2 sensor to measure the air/fuel mixture in the pipe in real time as well as recording the results so that they can be viewed after the fact. Hopefully by warming the bike up first and only running the sensor for tuning purposes, it will survive long enough to give me the results I'm after. If all goes well, I should be able to dial the bike in as close as possible sans dyno. Stay tuned!
The first step is to install the O2 sensor bung in the pipe. This needs to be between 10 & 2 o'clock to keep moisture, oil, and fuel from collecting on the sensor and killing it. The distance from the exhaust port should alleviate any excessive heating issues that can also kill the sensor and result in a fairly accurate A/F reading.
Rotax Lamby build-203 by
PotvinV8, on Flickr
Rotax Lamby build-204 by
PotvinV8, on Flickr
With the O2 sensor installed...
Rotax Lamby build-205 by
PotvinV8, on Flickr
Once I'm satisfied with the tune, the bung will be plugged and the sensor removed...
Rotax Lamby build-206 by
PotvinV8, on Flickr
Here's the pipe installed on the bike with the O2 sensor installed...
Rotax Lamby build-207 by
PotvinV8, on Flickr
And the display that will need to be temporarily mounted while tuning commences...
Rotax Lamby build-208 by
PotvinV8, on Flickr
Hopefully this time tomorrow, I'll have some results...
