Is there a pump from the gas tank?
Just wondering how the gas is fed: normally gravity fed so couldn't see how it now worked?
Also: although I realise some large frame coops (I was a bit of a PX anorak once!) have a spare wheel there how bigs the new tank -looks like 6-7litres (hence 6-7 kilos?) is it not more unbalanced than normal?
Great engineering though, I love great engineering!
Sportique
Thanks c*untspeed, to be honest it was a pain in the ass to make, and i wouldn't do it again, next time i would do it in alloy.
timexit17 wrote:Is there a pump from the gas tank?
I run a mikuni pump and there is also a header tank under the seat, so the main tank feeds the header tank and the header tank is gravity feed to the carb, i have not had time to fill up with water yet to test, but I'm hoping 8 to 10 lts, With the engine on one side and the tank on the other i'm hoping it should be a nice ride.
- carlos fandango
Your making a very nice job of the whole scoot , what's your thoughts on the effect of ethanol on the fiberglass though ?
You should be ok if you put a decent tank sealer in the tank first.carlos fandango wrote:Your making a very nice job of the whole scoot , what's your thoughts on the effect of ethanol on the fiberglass though ?
I think you would be better of, safe than sorry and a buggered tank.C*NTSPEED wrote:would there be enough ethonal to cause any isses tho
- Muttley McLadd
I think it's only Gul putting it in the petrol, here. Fairly sure BP aren't.
Hoping to have it back from the painter before christmas!!
Well it s not Christmas any more, but i finally got this last night!
