I'm looking for 2 good coats and I'll flat the filler primer back prior to spraying the colour coats and see what it looks like.
1, how many coats of filler and primer did u use?
2, have u rubbed down the primer after spraying to your parts?
3, so i take it your planning to use 2k paint then. is it easy to use?
4, ive priced up from my local paint supplier for a lambretta, i'm looking at doing mine in ford st orange and was quoted 110 quid for every thing i need excluding sanding paper not bad i thought
I have been told celly is much easier to spray then 2k, not sure which way I'll go yet.
£110 sounds brillaint considering being quoted anything from £800 - £1100 is the norm these days....
I think spraying a car would be less hassle, with a car you have several large flattish panels but with a scooter you have lots of small parts which will take more time
I've sent you a pm about the filters.............
