Chain case leaking
Posted: Sat Jul 18, 2020 4:27 pm
by Simon lambretta
Hi.i have an oil leak from chain casing.Will it affect the performance of the engine.Its only a small leak.cheers simon
Re: Chain case leaking
Posted: Sat Jul 18, 2020 6:36 pm
by Lambretta67
I would have thought if oil can get out air can get in
Posted: Sat Jul 18, 2020 6:42 pm
by drunkmunkey6969
Lambretta67 wrote:I would have thought if oil can get out air can get in
Air in the chaincase is not a problem. No oil in the chaincase is a problem
Posted: Sat Jul 18, 2020 6:43 pm
by drunkmunkey6969
Simon lambretta wrote:Hi.i have an oil leak from chain casing.Will it affect the performance of the engine.Its only a small leak.cheers simon
As long as you keep it topped up at all times it will be fine, but it’s probably an easy fix if you have a go.
Posted: Sun Jul 19, 2020 6:30 pm
by hendy
If it's from the gasket face, Darrell Taylor does some lovely thick gaskets that compensate for minor damage and heat distortions really well. They've worked for me a couple of times.
Posted: Sat Aug 01, 2020 9:32 am
by Simon lambretta
Hi all, replaced gasket with a cork one.Reason for the leak 2 studs had come loose. So I heli coiled them in.I hope that’s the corrrect bodge.Cheers Simon
Posted: Tue Aug 25, 2020 4:43 pm
by EddieStone
Lambretta Upgrades do really nice gaskets in different thicknesses.
