Inner Tube Sizing
pooliepfr
Main scooter: Vespa PX 125
Hi, another newby question.
The inner tube i've removed from my front wheel says 300/350-10. Will 350/400-10 be ok?
gaz_powell
yes it will be fine on a PX
Pressure should be circa 18 front 26 rear solo
pooliepfr
gaz_powell wrote: Tue Aug 27, 2019 10:13 pm yes it will be fine on a PX
Great, thanks again Gaz.
pooliepfr
UPDATE...
Not sure if this is a brand issue or size issue, but when fitting the Vee Rubber 350/400-10 inner tube with a 90 degree valve, the valve ever so slightly catches the brake. I've done a bodge to hold the valve down a little but thought i'd share this info.
gaz_powell
Its the brand, some 90 deg valves are fine on front.
Some are longer than others.
Change it, you dont want any stress or impact on the valve.
On vespas ive only ever used Michelin Airstop with no problem on back or front.
A learning curve.....that what scooters are.
pooliepfr
gaz_powell wrote: Thu Aug 29, 2019 5:31 pm Its the brand, some 90 deg valves are fine on front.
I've got a couple of Michelin Airstops on order, thanks.
    Users browsing this forum: No registered users and 23 guests
