Semi hydraulic set up
- registered user
- Main scooter: Series 1 li150 1958
- Contact:
The plunger on the remote master cylinder is not fully returning keeping the brake on slightly, is this Donald ducked? If so it’s the grimeca one where would I get one pronto style?
- registered user
- Contact:
No It doesn’t return I’ve ordered 1 from Europe
the pin that the lever pivots on can corrode and stick which stops it from working smoothly makes it stick; take the two little circlips off remove the pin clean it up use copper slip on the pin and pivot and it might work
C’est la vie
