Leak down test spark plug
- registered user
- Main scooter: lambretta gp
- Contact:
have you tried tightening it a bit more, the aluminium crush washer should seal it unless your head has a defect, maybe try a new plug, could try a little bit of silicone around the washer, but not too much you might seal it in for good,
- ForemanBob
- registered user
- Main scooter: GP RT230
- Contact:
I'd try a new plug an crush the washer down to suit.
Failing that a little grease to try to create a seal...
But if its that bad i'd be looking to get the seat machined flat..
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
when i built my ts1 engine i put the champion plug in that rayspeed recommends and did my leak test all ok apart from that plug changed to ngk and no more leak never used a champion since
- registered user
- Main scooter: Lambretta series 3
- Contact:
This was a NGK Gary .garry inglis wrote: ↑Sun May 27, 2018 4:18 pm when i built my ts1 engine i put the champion plug in that rayspeed recommends and did my leak test all ok apart from that plug changed to ngk and no more leak never used a champion since
- garry inglis
- registered user
- Contact:
Try a another plug and test and when that's ok test another one and keep as a spare as once engine is in the bike we really don't test them anymore
