Reed mount quattrini - what carb to use?
scootnz
Main scooter: Vespa Super
Hi, we are trying to set up a rear facing carb on a quattrini M1XL.
We have tried to fit a Dellorto PHBH 30mm to the stock reed mount, but it won't fit.
Is there a special manifold rubber to suit Dellorto style carbs? Or is there an alternate solution for the manifold?
This is for an event scooter for an April 2016 event - would love to get it road tested well before then!
Hope someone can help with good advice.
Jess
wack 63
Main scooter: '71 GP TS1
cartmel808
I use a Delly PHBH 30 on mine & it fits the standard Quattrini manifold without any problem... think I used one of the SIP Serie Pro manifold rubbers for 30mm carb - like this one; http://www.sip-scootershop.com/en/produ ... +_22301500
ImageUntitled by Graham Dent, on Flickr
scootnz
thanks, apparently that special manifold came with the kit, but it got sold to someone else who needed it! We'll track one down and try it.
Sent from my Nexus 7 using Tapatalk
