Welded up toolbox door pictures
lambretta007
Main scooter: Vespa GL
Hello,
I have a lambretta frame that has had its toolbox door welded up but when i have taken back the paint hoping to find some small spot welds to grind away it looks like its going to be a little more difficult than that. I want to return it to having a useable toolbox so has anyone any suggestions on the best way to do this? It looks like the original door has been welded in place.
Thanks in advance for any advice. :shock:
Looks like it's been done properly. Might be easier to get a new or donor loop.
lambretta007
I might just have to accept I can't use the toolbox.... :cry:
You could try knocking it out from the inside, the weld might give, but you might distort the rim and / or loop
lambretta007
I thought about sacrificing the toolbox door and cutting it down the middle and trying to fold it out? Not sure if that is possible or makes sense but will hopefully cause less damage if it doesn't work? I was thinking the welding might snap...... Worst case scenario I have to get it welded back up.
DigDug
Looks like a neat job. 8-)
Did you have to do that?
lambretta007
Yes neat job done by someone else but I want a toolbox if possible if it's going to be too much hassle I will live with it as is.
monument7
Main scooter: Li auto conversion 180
See if someone wants to swap you for a loop with door
barnsleybilly
Main scooter: Li200
For what you can get in a standard toolbox is it worth the hassle?
Better with a twin tank conversion and a legshield toolbox
lambretta007
Really want a standard looking gp so the toolbox door and the holes in the side panels need to be returned to the factory design.... I just prefer the look.....each to their own :roll:
