GT kit Dyno graphs
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
eden
GT kit Dyno graphs
Three engines on this graph.
blue line is my GT230 30mm PHBH and Fran race exhaust
red line is GT200 out of the box 30mm PHBH and Fran race exhaust (we later found out this had an air leak on the mag gasket face)
Green line is a tuned GT186 25mm carb filtered and MB devtour exhaust
Knowledge
I like the look of the bhp lines, but are the lower lines the torque? These look particularly low. (10-12ftlbs). Is there an explanation?
Martin
eden
torque is the numbers on the right, bhp numbers on the left. look at the image using the subsilver forum style and you can see all of the image. no idea why prosilver is chopping off the sides of images, i'm sure it didn't do that before! :?
read the higher curves from the numbers on the left..
read the lower curves from numbers on the right..
green is 17 lb-ft
red is 18 lb-ft
blue is 19 lb-ft
slangen
Main scooter: TV200
Eden, what is done to the gt186, and who did it if you don't mind me asking? Pretty impressive figures for a bolt on 200cc there, looks quite drivable too.
eden
Chris Sturges did it a few years ago, there are a few GT186's like that round here in Birmingham.
The 200's are very drivable, they behave like a standard 200 till they get on power then they go like stink. best kit out there in my opinion.
Where did the graphs go?
bazza3004
I was wondering the same thing adam
I was hoping to reference these in a response to another thread/question but found that they were no longer showing :(
It's always done that as far as I recall
Mr G in NYC
Main scooter: SX200
Adam_Winstone wrote:Where did the graphs go?
Yes ..... wondering the same . can you repost the graph Eden ?
cheers G
