Had a problems with the kick start on my gp.....sleeve keeps slipping of and wont engage first gear... just wondering what parts to replace while ive got it stripped out save stripping again if anything else is worn??
cheers ...
kickstart problems GP
- Toddy
- Main scooter: Lambretta Series 1
By sleeve do you mean Plunger ??clockwork wrote:Had a problems with the kick start on my gp.....sleeve keeps slipping of and wont engage first gear... just wondering what parts to replace while ive got it stripped out save stripping again if anything else is worn??
cheers ...
- Main scooter: gp 150 tuned
yes sorry mate ...Toddy wrote:By sleeve do you mean Plunger ??clockwork wrote:Had a problems with the kick start on my gp.....sleeve keeps slipping of and wont engage first gear... just wondering what parts to replace while ive got it stripped out save stripping again if anything else is worn??
cheers ...
- Toddy
Sounds like the spring is worn but strip down and check all parts the plunger teeth may be worn as well if you look on scooter restorations site there's a parts diagram for the kickstart shaft assembly that gives you an idea of what you may need mate
cheers toddy ill have a lookToddy wrote:Sounds like the spring is worn but strip down and check all parts the plunger teeth may be worn as well if you look on scooter restorations site there's a parts diagram for the kickstart shaft assembly that gives you an idea of what you may need mate
