lambretta 290 rotax
holty
Main scooter: lambretta gp
garry inglis wrote: Sun Aug 06, 2017 6:24 am Yes great to meet you as well holty had a great day out and fun ride back home acting like I stole it lol see you at Bridlington 😎
yes it was a good day, i might just have this up and running for next year, yes see you at brid :D
holty
done a bit more work on the exhaust pipe , more pics to follow later
ImageIMG_1118 by stephen holt, on Flickr
ImageIMG_1119 by stephen holt, on Flickr
garry inglis
looks good holty how are you working out the tuned length too suit the engine tune or are you just making it fit and see what adjustments may be needed
holty
your on the right wavelength there garry, yes ive added a few centimeters in a couple of places the help fitment, but more importantly to get the length needed.
garry inglis
I learnt from Martin at chiselspeeds when he trys his ads 3/5/6 he has them on the wall as a length of pipe with the combustion chamber but can fit each one by the two exhaust studs and has them sticking out from the side on the dyno looks weard but you can see the length difference in each pipe which we no is so important you'll sort it holty you have engineered harder projects than this
holty
just about done, might add one mounting later
ImageUntitled by stephen holt, on Flickr
holty
clutch spider altered to fit the basket, its bolted and welded, built the welds up the fingers a bit to add support
holty
clutch basket extended, i will be reducing the size a bit later when ive worked out how many plates i can squeeze in
garry inglis
thats some neat welding on the basket why not try for an 8 plate packer plate for casing extend kickstart shaft go on holty be the first go on go on
holty
garry inglis wrote: Wed Sep 06, 2017 7:05 pm thats some neat welding on the basket why not try for an 8 plate packer plate for casing extend kickstart shaft go on holty be the first go on go on
ive got 2 5mm packers and the extended center bush and kickstart extension , i intend to get 2 sixplate conversions and see how many plates i can get in :mrgreen:
