Page 8 of 20
Re: lambretta 290 rotax
Posted: Fri May 05, 2017 11:00 pm
by holty
hi daz, simple way to think of is a one way valve, its self governing, in other words when the engine crankcase creates a vacumn the valve opens allowing fuel and air mixture in, when a positive crankcase pressure is created the valve closes so ingested mixture cannot escape,its then sent to the transfer ports and then combusted above the piston, allows inlet timing to be much longer duration than that of a normal piston port engine, a more modern inlet system introduced in motorcycles mainly during the 1970s/80s and is standard fitment on most modern 2 strokes these days, helps to reduce fuel spitback out of the carb as well.
Posted: Sat May 06, 2017 7:35 am
by dazblakey
Cheers Holty
Read all this thread tonight really interesting great explanations keep it up mate and the others guys
Sent from my D6603 using Tapatalk
Posted: Sat May 13, 2017 9:47 pm
by holty
ive done an all day session in the garage working on my case, heres a few pics, first is the crankcase opened up big engough for the crank webs, next shows the circlip to retain the drive side main bearing, and you can see the trench ive cut to give the big end some clearance, and then a view looking into the inlet, some more shaping here and there, but happy with the progress.
[img
IMG_0631_zpsyom10gfk by
stephen holt, on Flickr][/img]
[img
IMG_0645_zpswwuejkwu by
[img
IMG_0646_zpsopw0kskq by
Posted: Fri Jul 21, 2017 9:36 pm
by holty
[img
IMG_0941 by
a pic showing the drive side oilseal fitted
Posted: Fri Jul 21, 2017 9:44 pm
by holty
before the oilseal was fitted, bearing fitted and circlip
[img
IMG_0932 by
Posted: Fri Jul 21, 2017 9:58 pm
by holty
[img
IMG_0942 by
first fitting of the crankshaft
[img
IMG_0943 by
and then magflange and packers in place
Posted: Fri Jul 21, 2017 10:02 pm
by holty
[img
IMG_0944 by
piston fitted to rod, just to check clearance at bdc, i neednt have worried there was plenty of clearance.
Posted: Sat Jul 29, 2017 6:46 pm
by holty
Posted: Sat Jul 29, 2017 6:48 pm
by holty
i had o do some repairs to the endplate studs, so i added 2 extra ones while i was at it in an effort to make it stronger
IMG_0933 by
Posted: Sat Jul 29, 2017 6:54 pm
by garry inglis
hi holty that circlip on the bearing looks great and that reed valve opening looks massive what reed are you useing
