Page 3 of 4
Re: TUNED AVANTI TT3 30+
Posted: Sun Mar 15, 2015 6:08 pm
by Adam_Winstone
Peach running an Avanti too?! I didn't appreciate Peach being a man of such good taste (kidding)!
It sounds like Peach's is running well so it would be good to hear of his setup. As I posted recently in another thread, the other Avanti TT3 being run in our club runs very well and it was simply set up as Ron sent it to him, no jetting changes or anything.
Adam
Posted: Sun Mar 22, 2015 2:05 am
by Lambretta Sash
Colin, yes we did get it running a bit sweeter, give me a shout when you want to bring it over
Posted: Sun Mar 22, 2015 2:58 am
by coaster
Adam_Winstone wrote:Peach running an Avanti too?! I didn't appreciate Peach being a man of such good taste (kidding)!
Adam
On the run to Davos there were 3 Avanti's, all running 30mm PHBH and Peach was putting around 30% less fuel in that myself and the other Avanti at each stop
That said, I have finally ditched my faithful JL3 in favour of an Avanti Supertourer and I THINK the fuel consumption is better.
Thanks Sach, I'll be in touch.
Colin
Posted: Mon Mar 23, 2015 6:20 pm
by Adam_Winstone
What, if any differences are there from one to another? When I ran to the last Euro Ireland my fuel economy was terrible at the cruising speed being set by my companion's 175 so I raised the needle clip 1 position (dropped clip and made it weaker) and that little difference alone made a massive difference to my fuel consumption. I changed back once we had returned from the rally as it then felt a tad weak/hot at slightly higher speeds.
See if you can 'spot the difference' between the bikes... then tell us if you find anything
Posted: Mon Mar 23, 2015 10:18 pm
by coaster
I running 30 PHBH and all had standard ignitions but Peach (Angry Bloke) was the only one with an MB Clubman. His PHBH was also fitted with a 50 slide if I remember correctly...don't know what effect that would have on consumption?
Posted: Mon Mar 23, 2015 10:59 pm
by Adam_Winstone
Higher the slide number (PHBH) the leaner it is so it could well be that this made all the difference. A pal of mine recently borrowed a 45 slide from me to clean up his rich spot on pull away (not TT3) and he is happy with the result... but this was tested thoroughly by him to ensure that it wasn't too weak.
Posted: Fri Sep 30, 2016 9:33 pm
by Adam_Winstone
FYI - I'm currently playing with pipes and gearing again on a slightly modified TT3... not sure why as my bike is already fast enough! I'm currently looking to swap out a Fran Race (4.8) for a Fran Supertourer and possibly 4.6:1 as I run a Supertourer on my standard TT3, which combined with Agusto 6K unit is a dream right through the rev range.
Ooh, tinkering
Posted: Fri Sep 30, 2016 10:36 pm
by coaster
I had problems with my Avanti as revealed when I went over to Sach's dyno in Lowestoft. The barrel was badly damaged where the plating had worn through probably due to me not gapping the rings correctly when I changed them
I got it re-plated and a new piston but it sat on the shelf for a year until a few weeks ago when I decided to resurrect it but with a reed valve. Still running it in but it pulls strongly in 4th without any hesitation from the low 20's mph until 45 where the power band starts to kick in up to my self imposed 60ish limit.
I've not had a long enough run to gauge fuel consumption yet and it needs fully jetting in yet.
Posted: Fri Sep 30, 2016 11:55 pm
by Adam_Winstone
^... where is the 'LIKE' button?
Posted: Sat Oct 01, 2016 1:28 am
by rosscla
Still not got one...
