Gear oil vs two cycle mixing oil
dirtyhandslopez
Vespa's run straight 30w in the gearbox. So can Lambrettas, I reckon the chain gets a bit niosey with thin oil, but less drag. 30w can also successfully be used as two stroke, as can most oils if you shake the mix up enough:)
That's not going anywhere...
