they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
looks up my street for S2
New Rear Shock from Readspeed
- registered user
- Contact:
- carlos fandango
- registered user
- Contact:
What ! pinks not manly ? ....its the new Matt BlackDoom Patrol wrote:You've got to look at it in perspective. When a new set of BGM dampers cost more than that it sounds reasonable. You could perhaps have chosen a more manly colour though.
Its actually red
- carlos fandango
- registered user
- Contact:
There adjustable 295mm -315mm ishfred wrote:How long are they?
http://www.ekmpowershop2.com/ekmps/shop ... 6219-p.asp
Cheers Carlos
- coaster
- registered user
- Contact:
Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
- soulsurfer
- registered user
- Contact:
The locknut is on the bottom eye, it adjusts the length the same as a BGM rear shock by the looks of it.coaster wrote:Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
- Bofs
- registered user
- Main scooter: Zundapp Betta 500
- Contact:
Have one ordered for a Series 2, will report back when it`s fitted.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Bad Samaritans SC
- coaster
- registered user
- Contact:
Thanks Mikesoulsurfer wrote:The locknut is on the bottom eye, it adjusts the length the same as a BGM rear shock by the looks of it.coaster wrote:Will that actually alter the length or just the load on the spring? I'm also curious about the length as the mention in Scootering said suitable for series 1, 2 and 3gaz_powell wrote:they look adjustable with a threaded/lock nut - blue nut on top eyelet (Top on th picture)
- Bofs
- registered user
- Contact:
Right, it landed today and on first inspection looks good. It was set for 300mm length on arrival but things got decidedly worrying when I adjusted it out to 315mm for fitment to the series 2 I`m planning to fit it too
As it arrived 300mm length
Adjusted to 315mm
The worrying bit, 4mm of thread to secure the ends together when adjusted to 315mm
That looks too dodgy for words,there`s no way that is safe. I`ve checked inside the shock and there is no room for a longer threaded eye section so seriously this shock should have two different eyes to accommodate each length instead of being marketed as a one-size-fits-all.
It looks perfectly fine in 300 length but if you`re planning on fitting this to anything needing 315mm length then hold fire yet
I`ve contacted Readspeed and await their reply.
Adjusted to 315mm
Bad Samaritans SC
Bad Samaritans SC
