fitting the exhaust after a respray i have fitted the stub first then fitted everything else slack, then ive started from the back
tightening every thing up now the problem is that the kick start wont go back to the rubber stop it hits the expansion part
just before it becomes narrow for the muffler section. Hope someone has any ideas as its doing my head in...
franspeed touring exhaust
- Toddy
- Main scooter: Lambretta Series 1
Tosh wrote: ↑Sun Apr 07, 2024 6:56 pm fitting the exhaust after a respray i have fitted the stub first then fitted everything else slack, then ive started from the back
Leave it all as loose fit and try the kickstart see if it returns then set in place and tighten up ?
Thanks toddy for getting back to us but ive tried that its as though the expansion part sits to low but if i pull it up lets say towards
the shark fin so it misses the kick start, then it doesnt line up with the rear muffler section
yes its a bgm 195 non reed it had a clubman 42mm on for the coast to coast last year just thought id have a change,
well just got back in from the garage ive managed to fit it but ive dropped the kickstart down a notch so it doesnt hit the exhaust.
tomorrow ill start it and see if it doesnt make the clicking sound, FINGERS CROSSED
- Toddy
Good luckTosh wrote: ↑Mon Apr 08, 2024 9:37 pm yes its a bgm 195 non reed it had a clubman 42mm on for the coast to coast last year just thought id have a change,
