Dog support
bristolmod
HxPaul wrote:Unfasten the two bolts and nuts that hold it on to the support leg and remove it.Next place a thick peice of wood under the back of the frame,jack up without unfastening anything and the frame will be raised enough to remove the sidecover
https://www.google.co.uk/search?q=pictu ... pReIKtashM:
but its designed to allow the side cover off easily- something is
amiss. It would appear that the engine as a whole is too close to the support. Either the support is bent in for some reason, or, hopefully not, the engine/ frame is bent out.
Scootering since 1968.
hendy
Aye, what he said. I have no bother with this.
gaz_powell
Ive not had any trouble in the past - sounds like your support arm is pushed in ???
bristolmod
engine mount collapsed?
fluff34567
As above check engine mounts , do you have offset cones in the frame?
dazblakey
fluff34567 wrote:As above check engine mounts , do you have offset cones in the frame?
This is a new one on me can you elaborate please
fluff34567
On my frame where I know the leg is out of position I can still get the case off .. should be 20cm.from.frame centre line to the hole in L bracket btw.
If the engine is tilted combined with something else that isn't right then it may be a bit harder to get the case off.
    Users browsing this forum: No registered users and 25 guests
