I bought one of the early BGM shocks with the white springs many years ago but never got around to fitting it. Anyway when I took it out the box at the weekend oil had obviously leaked out
Has anyone rebuilt one of these shocks?
BGM Rear Shock
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
I don't know what the availability is like around your parts, but it would be easier to change it. I wouldn't have thought it should leak like that regardless.
- corrado
- Dealer
- Main scooter: Lambretta GP
I doubt it as it's probably a few years old and well out of warranty, used or unused. If the supplier took it back they'd be in the same boat with the manufacturer.Doom Patrol wrote: but it would be easier to change it.
- Doom Patrol
There is that.
- Main scooter: DL 150 1970
There were seal problems with alot of the early BGM shocks, try contacting Scooter Center.
Slow is the new fast!
Martincorrado wrote:I doubt it as it's probably a few years old and well out of warranty, used or unused. If the supplier took it back they'd be in the same boat with the manufacturer.Doom Patrol wrote: but it would be easier to change it.
Understand your position as a dealer/supplier, but surely the manufacture would be easily able to tell that the part is unused and has never been fitted?
If it was mine I'd be seeking to return it to the manufacture, through the dealer you bought it from, and I would expect a refund or replacement?
Surely it is not too much to at least return it to the manufacture FOC?
Lambretta part or not, if the item is clearly defective (an unused rear shocker leaking oil in the box is clearly defective) then Trading Standards would be the place to go if the manufacture wasn't interested initially.
Had mine a year before i fitted it and after 2 weeks of light use seal had went and leaking oil.
sent back to MB and replaced straight away no issues .
It was clearly obvious the shock was new and faulty like a good few of the early batches they got back,,,,,,,,,
nothing to lose by sending it back.
good luck
good luck
- Main scooter: Li 125
If its older tha a 12 month,then they dont need to do anything,new or used.But its worth a go,or maybe pay them to repair it.Toot-oasc wrote:Martincorrado wrote:I doubt it as it's probably a few years old and well out of warranty, used or unused. If the supplier took it back they'd be in the same boat with the manufacturer.Doom Patrol wrote: but it would be easier to change it.
