First scoot (Lambretta) which model is best for a newb?
Rs fruitbat
Well done , it looks a good un ;)
bristolmod
Andy- just check out the routing of the speedo cable- it looks like its been routed wrongly. The correct routing is in Stickys book somewhere.
5 min job to correct
Scootering since 1968.
dave411
Main scooter: Li 125
:D :D :D a happy ending :D :D :D
britcay
Main scooter: Lambretta Li150 S3
Yep, that's the plan! The A1/A2 classifications are crazy tho. I could "learn" on a relatively powerful 125 but be unable to learn to ride a 150 scoot on CBT which is way less than 14bhp!
Why do CCs even come into it surely it's all about the power and weight?
Anyhow I have Stickys book and a chair in my garage (plenty of room now!) I'll check that speedo cable thanks Chris. You are the king of the scrutineers!
ArmandTanzarian
britcay wrote:Yep, that's the plan! The A1/A2 classifications are crazy tho. I could "learn" on a relatively powerful 125 but be unable to learn to ride a 150 scoot on CBT which is way less than 14bhp!
If you're expecting government rules to be based on logic and common sense then I fear that you're in for a lot of disappointments :D
britcay
True enough, Armand !
That a bit better, Chris? ;)
bristolmod
nicely rerouted! that silver disc around the link bolt. Appears to be the same type as is fitted inside the mechanism to shim out the link vs the fork inner "boot".
Presumably these are fitted internally as well?
Fux
Main scooter: li150 S2
Congrats .That looks like an honest and tidy scoot.
    Users browsing this forum: Majestic-12 [Bot] and 5 guests
