Anyone know if these will fit a Lambretta and if so would they be an improvement.
http://www.ebay.co.uk/itm/Classic-Mini- ... 1c1fa43ee8
Steve
Front Dampers
you would probbably need jet type damper studs to fit them ...improvement i dont know sorry
But they dampen in boh directions not the one direction needed for lambretta
dont know for sure but it has been said these are adjustable to almost dial out the compression damping although you could assume then the rebound would be very harsh
as i said ...not fitted so cant comment but i think id go with the bgm one personally
- panamesc
i have those lowered spax on my lince , close to the softest set-up , it works like new dampers !
i've done some miles without any problems ....
![Image](http://img.photobucket.com/albums/v80/fordfan/lince%20200/xyz034.jpg)
![Image](http://img.photobucket.com/albums/v80/fordfan/lince%20200/Sanstitre.jpg)
http://scooterotica.org/forum/viewtopic ... 32&start=0
Dave Talbot from our club has the Spax dampers fitted to his spanish forks, and he says they are great.
forgot to say, he got the uprated ones, and they were 40 quid a pair.
Does anyone know if these are the standard or lowered type?
